Author Zing Zai Loo
3 min read
    • Why Smooth Flow?
    • The setup
    • Conclusion
    In Oct 2021, Salesforce announced that Workflow Rules and Process Builder would be retired opens in a new tab in the near future. Building flows using Flow Builder will be the way forward where it would be a one-stop shop for low-code automation.
    Why Smooth Flow?
    Smooth Flow updates the object’s Chatter post whenever an envelope status changes. I have saved Smooth Flow for last in my blog series as it is sosmooth, it applies to envelopes sent in Part 1 and Part 2.
    Example
    The setup
    Step 2: Get records
    Step 3: Create new resource
    Step 4: Update Chatter
    Author Zing Zai Loo
      Author Ashlae Long
      Ashlae Long
