Author Ahmed Shorim
3 min read
Obtain identity workflows available on your account (using the IdentityVerification:list API) and extract the workflowId associated with the one that you’d like to use.
Request:
Headers:
Authorization: Bearer {code}
Response:
    "identityVerification": [
            "workflowId": "{workflowID}",
            "workflowLabel": null,
            "steps": [
                    "name": "identify",
                    "type": "EnvelopeAccess"
            "signatureProvider": null,
            "inputOptions": []
            "workflowResourceKey": "",
            "steps": [
            "inputOptions": [
                    "isRequired": true,
Request:
Headers:
JSON Payload:
    "compositeTemplates": [
            "serverTemplates": [
                    "sequence": "1",
                    "templateId": "{templateId}"
            "inlineTemplates": [
                    "recipients": {
                        "signers": [
                                "email": "{recipientEmail}",
                                "name": "{recipientName}",
                                "recipientId": "1",
                                "identityVerification": {
                                    "workflowId": "{workflowId}",
                                    "steps": null,
                                    "inputOptions": [
                                            "name": "phone_number_list",
                                            "phoneNumberList": [
                    "sequence": "2"
    "status": "sent"
Response:
    "status": "sent"
Author Ahmed Shorim
    A Developer’s Guide to Building Agentic Agreement Workflows with Docusign Iris
    Author Gaurav Rajoria
    Gaurav Rajoria
